Message |
What your normal idle is depends on your ECU program. For a stock ECU, it should be ~750. [ http://z32.wikispaces.com/Idle+Control ] However, I emailed SZ to confirm on my chip, and they set the idle target for 900. Make sure your engine is up to temp too as the ECU will set a different timing on warmup. After that, follow the general advice for setting timing properly, where to get the signal from, etc.
